Programming Interfaces Guide
Setting and Removing Record Locks
When locking a record, do not set the starting point and length of the lock segment to zero. The locking procedure is otherwise identical to file locking.
Contention for data is why you use record locking. Therefore, you should have a failure response for when you cannot obtain all the required locks:
This example shows a record being locked by using fcntl(2).
 	struct flock lck;
 	lck.l_type = F_WRLCK;	/* setting a write lock */
 	lck.l_whence = 0;	/* offset l_start from beginning of file */
 	lck.l_start = here;
 	lck.l_len = sizeof(struct record);
 	/* lock "this" with write lock */
 	lck.l_start = this;
 	if (fcntl(fd, F_SETLKW, &lck) < 0) {
 		/* "this" lock failed. */
 		return (-1);
The next example shows the lockf(3C) interface.
#include <unistd.h>
 	/* lock "this" */
 	(void) lseek(fd, this, SEEK_SET);
 	if (lockf(fd, F_LOCK, sizeof(struct record)) < 0) {
 		/* Lock on "this" failed. Clear lock on "here". */
 		(void) lseek(fd, here, 0);
 		(void) lockf(fd, F_ULOCK, sizeof(struct record));
 		return (-1);
You remove locks in the same way the locks were set. Only the lock type is different (F_ULOCK). An unlock cannot be blocked by another process and affects only locks placed by the calling process. The unlock affects only the segment of the file specified in the preceding locking call.
