The following examples illustrate specific aspects of the madv.so.1 shared object.
This configuration applies advice to all ISM segments for applications with exec names that begin with foo.
$ LD_PRELOAD=$LD_PRELOAD:madv.so.1 $ MADVCFGFILE=madvcfg $ export LD_PRELOAD MADVCFGFILE $ cat $MADVCFGFILE foo*:ism=access_lwp
This configuration sets advice for all applications with the exception of ls.
$ LD_PRELOAD=$LD_PRELOAD:madv.so.1 $ MADV=access_many $ MADVCFGFILE=madvcfg $ export LD_PRELOAD MADV MADVCFGFILE $ cat $MADVCFGFILE ls:
Because the configuration specified in MADVCFGFILE takes precedence over the value set in MADV, specifying * as the <exec-name> of the last configuration entry is equivalent to setting MADV. This example is equivalent to the previous example.
$ LD_PRELOAD=$LD_PRELOAD:madv.so.1 $ MADVCFGFILE=madvcfg $ export LD_PRELOAD MADVCFGFILE $ cat $MADVCFGFILE ls: *:madv=access_many
This configuration applies one type of advice for mmap() regions and different advice for heap and shared memory regions for applications whose exec() names begin with foo.
$ LD_PRELOAD=$LD_PRELOAD:madv.so.1 $ MADVCFGFILE=madvcfg $ export LD_PRELOAD MADVCFGFILE $ cat $MADVCFGFILE foo*:madv=access_many,heap=sequential,shm=access_lwp
