The lgrp_version() function discussed in this section must be used to verify the presence of a supported lgroup interface before using the lgroup API.
#include <sys/lgrp_user.h> int lgrp_version(const int version);
The lgrp_version() function takes a version number for the lgroup interface as an argument and returns the lgroup interface version that the system supports. When the current implementation of the lgroup API supports the version number in the version argument, the lgrp_version() function returns that version number. Otherwise, the lgrp_version() function returns LGRP_VER_NONE.
#include <sys/lgrp_user.h> if (lgrp_version(LGRP_VER_CURRENT) != LGRP_VER_CURRENT) { fprintf(stderr, "Built with unsupported lgroup interface %d\n", LGRP_VER_CURRENT); exit (1); }
