Programming Interfaces Guide
check -access
The -access option turns on access checking. RTC reports the following errors:
baf
Bad free
duf
Duplicate free
maf
Misaligned free
mar
Misaligned read
maw
Misaligned write
oom
Out of memory
rua
Read from unallocated memory
rui
Read from uninitialized memory
rwo
Write to read-only memory
wua
Write to unallocated memory
The default behavior is to stop the process after detecting each access error. This behavior can be changed using the rtc_auto_continue dbxenv variable. When set to on, RTC logs access errors to a file. The file name is determined by the value of the rtc_error_log_file_name dbxenv variable. By default, each unique access error is only reported the first time the error happens. Change this behavior using the rtc_auto_suppress dbxenv variable. The default setting of this variable is on.
