UNIX domain sockets are named with UNIX paths. For example, a socket might be named /tmp/foo. UNIX domain sockets communicate only between processes on a single host. Sockets in the UNIX domain are not considered part of the network protocols because they can be used to communicate only between processes on a single host.
Socket types define the communication properties visible to a user. The Internet domain sockets provide access to the TCP/IP transport protocols. The Internet domain is identified by the value AF_INET. Sockets exchange data only with sockets in the same domain.
The socket(3SOCKET) call creates a socket in the specified family and of the specified type.
s = socket(family, type, protocol);
If the protocol is unspecified (a value of 0), the system selects a protocol that supports the requested socket type. The socket handle (a file descriptor) is returned.
The family is specified by one of the constants defined in sys/socket.h. Constants named AF_suite specify the address format to use in interpreting names.
The following creates a datagram socket for intramachine use:
s = socket(AF_UNIX, SOCK_DGRAM, 0);
Set the protocol argument to 0, the default protocol, in most situations.
A socket is created with no name. A remote process has no way to refer to a socket until an address is bound to the socket. Communicating processes are connected through addresses. In the UNIX family, a connection is composed of (usually) one or two path names. UNIX family sockets need not always be bound to a name. If they are, bound, duplicate ordered sets such as local pathname or foreign pathname can never exist. The path names cannot refer to existing files.
The bind(3SOCKET) call enables a process to specify the local address of the socket. This creates the local pathname ordered set, while connect(3SOCKET) and accept(3SOCKET) complete a socket's association by fixing the remote half of the address. Use bind(3SOCKET) as follows:
bind (s, name, namelen);
The socket handle is s. The bound name is a byte string that is interpreted by the supporting protocols. UNIX family names contain a path name and a family. The example shows binding the name /tmp/foo to a UNIX family socket.
#include <sys/un.h> ... struct sockaddr_un addr; ... strcpy(addr.sun_path, "/tmp/foo"); addr.sun_family = AF_UNIX; bind (s, (struct sockaddr *) &addr, strlen(addr.sun_path) + sizeof (addr.sun_family));
When determining the size of an AF_UNIX socket address, null bytes are not counted, which is why you can use strlen(3C).
The file name referred to in addr.sun_path is created as a socket in the system file name space. The caller must have write permission in the directory where addr.sun_path is created. The file should be deleted by the caller when it is no longer needed. Delete AF_UNIX sockets with unlink(1M).
Connection establishment is usually asymmetric. One process acts as the client and the other as the server. The server binds a socket to a well-known address associated with the service and blocks on its socket for a connect request. An unrelated process can then connect to the server. The client requests services from the server by initiating a connection to the server's socket. On the client side, the connect(3SOCKET) call initiates a connection. In the UNIX family, this might appear as:
struct sockaddr_un server; server.sun.family = AF_UNIX; ... connect(s, (struct sockaddr *)&server, strlen(server.sun_path) + sizeof (server.sun_family));
See Connection Errors for information on connection errors. Data Transfer tells you how to transfer data. Closing Sockets tells you how to close a socket.
