Use Barrier operations to resolve order-of-write-access memory model issues. Barrier operations also provide remote memory access error detection.
The barrier mechanism is made up of the following operations:
Initialization
Open
Close
Order
Successfully performing a close operation guarantees the successful completion of covered access operations, which take place between the barrier open and the barrier close. After a barrier open operation, failures of individual data access operations, both reads and writes, are not reported until the barrier close operation.
To impose a specific order of write completion within a barrier's scope, use an explicit barrier-order operation. A write operation that is issued before the barrier-order operation finishes before operations that are issued after the barrier-order operation. Write operations within a given barrier scope are ordered with respect to another barrier scope.
Initialize Barrier
int rsm_memseg_import_init_barrier(rsm_memseg_import_handle_t im_memseg, rsm_barrier_type_t type, rsmapi_barrier_t *barrier);At present, RSM_BAR_DEFAULT is the only supported type.
Return Values: Returns 0 if successful. Returns an error value otherwise.
Invalid segment handle
Invalid barrier pointer
Insufficient memory
Open Barrier
int rsm_memseg_import_open_barrier(rsmapi_barrier_t *barrier);Return Values: Returns 0 if successful. Returns an error value otherwise.
Close Barrier
int rsm_memseg_import_close_barrier(rsmapi_barrier_t *barrier);This function closes the barrier and flushes all store buffers. This call assumes that the calling process will retry all remote memory operations since the last rsm_memseg_import_open_barrier call if the call to rsm_memseg_import_close_barrier() fails.
Barrier not initialized
Barrier not opened
Memory access error
Connection aborted
Order Barrier
int rsm_memseg_import_order_barrier(rsmapi_barrier_t *barrier);This function flushes all store buffers.
Barrier not opened
Memory access error
Connection aborted
Destroy Barrier
int rsm_memseg_import_destroy_barrier(rsmapi_barrier_t *barrier);This function deallocates all barrier resources.
Set Mode
int rsm_memseg_import_set_mode(rsm_memseg_import_handle_t im_memseg, rsm_barrier_mode_t mode);This function supports the optional explicit barrier scoping that is available in the put routines. The two valid barrier modes are RSM_BARRIER_MODE_EXPLICIT and RSM_BARRIER_MODE_IMPLICIT. The default value of the barrier mode is RSM_BARRIER_MODE_IMPLICIT. While in implicit mode, an implicit barrier open and barrier close is applied to each put operation. Before setting the barrier mode value to RSM_BARRIER_MODE_EXPLICIT, use the rsm_memseg_import_init_barrier routine to initialize a barrier for the imported segment im_memseg.
Get Mode
int rsm_memseg_import_get_mode(rsm_memseg_import_handle_t im_memseg, rsm_barrier_mode_t *mode);This function obtains the current mode value for barrier scoping in the put routines.
Invalid segment handle.
