This section describes the steps taken by a client process. As in the server, the first step is to locate the service definition for a remote login.
bzero(&hints, sizeof (hints)); hints.ai_flags = AI_ALL|AI_ADDRCONFIG; hints.ai_socktype = SOCK_STREAM; error = getaddrinfo(hostname, servicename, &hints, &res); if (error != 0) { (void) fprintf(stderr, "getaddrinfo: %s for host %s service %s\n", gai_strerror(error), hostname, servicename); return (-1); }
getaddrinfo(3SOCKET) returns the head of a list of addresses in res. The desired address is found by creating a socket and trying to connect to each address returned in the list until one works.
for (aip = res; aip != NULL; aip = aip->ai_next) { /* * Open socket. The address type depends on what * getaddrinfo() gave us. */ sock = socket(aip->ai_family, aip->ai_socktype, aip->ai_protocol); if (sock == -1) { perror("socket"); freeaddrinfo(res); return (-1); } /* Connect to the host. */ if (connect(sock, aip->ai_addr, aip->ai_addrlen) == -1) { perror("connect"); (void) close(sock); sock = -1; continue; } break; }
The socket has been created and has been connected to the desired service. The connect(3SOCKET) routine implicitly binds sock, because sock is unbound.
