Programming Interfaces Guide
State Tables
The state tables describe the XTI/TLI state transitions. Each box contains the next state, given the current state (column) and the current event (row). An empty box is an invalid state/event combination. Each box can also have an action list. Actions must be done in the order specified in the box.
You should understand the following when studying the state tables:
Some of the state transitions listed in the tables below offer actions the transport user must take. Each action is represented by a digit derived from the list below:
The following table shows endpoint establishment states.
Table 8–4 Connection Establishment State
Event/State
T_UNINIT
T_UNBND
T_IDLE
opened
T_UNBND
bind
T_IDLE[1]
optmgmt (TLI only)
T_IDLE
unbind
T_UNBND
closed
T_UNINIT
The following table shows data transfer in connectionless mode.
Table 8–5 Connection Mode State—Part 1
Event/State
T_IDLE
T_OUTCON
T_INCON
T_DATAXFER
connect1
T_DATAXFER
connect2
T_OUTCON
rcvconnect
T_DATAXFER
listen
T_INCON [2]
T_INCON [2]
accept1
T_DATAXFER [3]
accept2
T_IDLE [3] [4]
accept3
T_INCON [3] [4]
snd
T_DATAXFER
rcv
T_DATAXFER
snddis1
T_IDLE
T_IDLE [3]
T_IDLE
snddis2
T_INCON [3]
rcvdis1
T_IDLE
T_IDLE
rcvdis2
T_IDLE [3]
rcvdis3
T_INCON [3]
sndrel
T_OUTREL
rcvrel
T_INREL
pass_conn
T_DATAXFER
optmgmt
T_IDLE
T_OUTCON
T_INCON
T_DATAXFER
closed
T_UNINIT
T_UNINIT
T_UNINIT
T_UNINIT
The following table shows connection establishment/connection release/data transfer in connection mode.
Table 8–6 Connection Mode State—Part 2
Event/State
T_OUTREL
T_INREL
T_UNBND
connect1
connect2
rcvconnect
listen
accept1
accept2
accept3
snd
T_INREL
rcv
T_OUTREL
snddis1
T_IDLE
T_IDLE
snddis2
rcvdis1
T_IDLE
T_IDLE
rcvdis2
rcvdis3
sndrel
T_IDLE
rcvrel
T_IDLE
pass_conn
T_DATAXFER
optmgmt
T_OUTREL
T_INREL
T_UNBND
closed
T_UNINIT
T_UNINIT
The following table shows connectionless mode states.
Table 8–7 Connectionless Mode State
Event/State
T_IDLE
snudata
T_IDLE
rcvdata
T_IDLE
rcvuderr
T_IDLE
