Task |
Description |
For Instructions, Go to ... |
Configuring a multipathing interface group with two interfaces |
Use the ifconfig command, the group parameter, -failover option, the deprecated option, and the /etc/hostname.interface file |
How to Configure a Multipathing Interface Group With Two Interfaces |
Configuring a multipathing group where one of the interfaces is a standby interface |
Use the ifconfig command, the group parameter, standby parameter, -failover option, and the /etc/hostname.interface file |
How to Configure a Multipathing Group With One of the Interfaces a Standby Interface |
Displaying the group to which a physical interface belongs |
Use the ifconfig command and the interface name |
How to Display the Group to Which a Physical Interface Belongs |
Adding an interface to a group |
Use the ifconfig command and the interface name | |
Removing an interface from a group |
Use the ifconfig command and a null string to disable IP network multipathing | |
Moving an interface from an existing group to a different group |
Use the ifconfig command and the group parameter |
How to Move an Interface From an Existing Group to a Different Group |
