IPv6 Administration Guide
IPv6 Extensions to the ifconfig Utility
The ifconfig utility now enables IPv6 interfaces and the tunneling module to be plumbed. The ifconfig(1M) utility uses an extended set of ioctls to configure both IPv4 and IPv6 network interfaces. The following table shows the set of options that are added to this utility. See How to Display Interface Address Assignments for a description of useful diagnostic procedures that use this utility.
Table 3–1 New ifconfig Utility Options
Option
Description
index
Set the interface index.
tsrc/tdst
Set tunnel source or destination.
addif
Create the next available logical interface.
removeif
Delete a logical interface with a specific IP address.
destination
Set the point-to-point destination address for an interface.
set
Set an address, netmask, or both for an interface.
subnet
Set the subnet address of an interface.
xmit/-xmit
Enable or disable packet transmission on an interface.
Enabling IPv6 Nodes provides IPv6 configuration procedures.
Examples—New ifconfig Utility Options
The following usage of the ifconfig command creates the hme0:3 logical interface to the 1234::5678/64 IPv6 address. This command enables the interface with the up option. The command also reports status. The command disables the interface. Finally, the command deletes the interface.
Example 3–1 Examples—Using addif and removeif
# ifconfig hme0 inet6 addif 1234::5678/64 up
Created new logical interface hme0:3
# ifconfig hme0:3 inet6
hme0:3: flags=2000841<UP,RUNNING,MULTICAST,IPv6> mtu 1500 index 2
		inet6 1234::5678/64
# ifconfig hme0:3 inet6 down
# ifconfig hme0 inet6 removeif 1234::5678
The following usage of the ifconfig command opens the device that is associated with the physical interface name. The command configures the streams that are needed for TCP/IP to use the device. The command reports the status of the device. The command configures the source and the destination address for the tunnel. Finally, the command reports the new status of the device after the configuration.
Example 3–2 Examples—Using tsrc, tdst, and index
# ifconfig ip.tun0 inet6 plumb index 13
ip.tun0: flags=2200850<POINTOPOINT,RUNNING,MULTICAST,NONUD,
IPv6> mtu 1480 index 13
		inet tunnel src 0.0.0.0
		inet6 fe80::/10 --> ::
# ifconfig ip.tun0 inet6 tsrc 120.46.86.158 tdst 120.46.86.122
		inet tunnel src 120.46.86.158  tunnel dst 120.46.86.122
		inet6 fe80::8192:569e/10 --> fe80::8192:567a
