System Administration Guide: Resource Management and Network Services
Where to Go From Here
Task
For Instructions
Configure another dial-out machine
How to Configure the Modem and Serial Port (Dial-out Machine).
Test modem connectivity by dialing out to another computer
cu(1C) and tip(1) man pages. These utilities can help you test if your modem is properly configured. Also, use these utitlities to test if you can establish a connection with another machine.
Get detailed information about the PPP configuration files
Using PPP Options in Files and on the Command Line.
Begin configuring the dial-in server
Configuring Devices on the Dial-in Server.
