System Administration Guide: Resource Management and Network Services
Type Field and /etc/uucp/Systems File
Example 40–5 shows a comparison between the fields in /etc/uucp/Devices and fields in /etc/uucp/Systems. The titles of each column apply only to fields in the Devices file.
The keyword that is used in the Type field of the Devices file is matched against the third field of the Systems file entries. In the Devices file, the Type field has the entry ACUEC, indicating an automatic call unit, in this instance a V.32bis modem. This value is matched against the third field in the Systems file, which also contains the entry ACUEC. See UUCP /etc/uucp/Systems File for more information.
Example 40–5 Type Field and /etc/uucp/Systems File Equivalent
File Name Type   Line  Line2 Class Dialer-Token-Pairs
Devices   ACUEC  cua/a -     38400 usrv32bis-ec
System    nubian Any   ACUEC 38400 9998888 ““ \d\d\r\n\c-ogin-\r\n\c-ogin.......
