Solaris 9 12/02 Release Notes
Upgrade Fails if /export Is Near Capacity (4409601)
If the /export directory is near full capacity and you upgrade to the Solaris 9 12/02 operating environment, space requirements for /export are miscalculated. The upgrade then fails. This problem commonly occurs if a diskless client is installed, or if third-party software is installed in the /export directory. The following message is displayed:
WARNING: Insufficient space for the upgrade.
Workaround: Before you upgrade, choose one of the following workarounds.
