Solaris 9 12/02 Release Notes
IA: PXE Network Boot Does Not Execute Successfully on Sun LX50 Systems (4725108)
If you use the Preboot Execution Environment (PXE) network boot to install the Solaris 9 12/02 operating environment on a SunTM LX50 system, the network boot might fail. The following message is displayed.
error: Assertion failure: - "rp->flags & RESF_ALT", "ur.c" line 80
The root filesystem is not mounted and the configuration assistant
has exited prematurely. Booting is unlikely to succeed.
CTL-ALT-DEL may be used to reset the machine.
Failover to boot interpreter - type ctrl-d to resume boot
Workaround: Choose one of the following workarounds.
