Solaris 9 12/02 Release Notes
SPARC: Systems With Multiple Interfaces Recognize All Interfaces as Usable After Installation or Upgrade (4640568)
If you install or upgrade to the Solaris 9 12/02 operating environment on a system with multiple network interfaces, the system recognizes all system interfaces as usable. Interfaces that are not plugged in to the network or that are not intended for use appear in the output of the ifconfig -a command. Additionally, interfaces with identical Ethernet addresses might be assigned identical IP addresses. The following error message is displayed.
ifconfig: setifflags: SIOCSLIFFLAGS: qfe3: Cannot assign requested address
This problem also occurs on systems that have the local-mac-address PROM variable set to false. The problem occurs because all interfaces are configured with the same IP address.
Workaround: Choose one of the following workarounds.
