Solaris 9 12/02 Release Notes
Uninstall Mode of Solaris 9 12/02 Documentation CD uninstaller Utility Does Not Work Properly (4675797)
If you run the Solaris 9 12/02 Documentation CD uninstaller in Uninstall All mode, the uninstaller removes only those documentation packages that are installed by default.
Workaround: Run the uninstaller in Uninstall Partial mode. Select the specific packages you want to uninstall.
