Solaris 9 12/02 Release Notes
SPARC: luupgrade Command Cannot Add Patches When a Patch List File Is Specified (4679511)
If you use the -s option with the luupgrade command to add patches with a directory and a patch list file, the patches are not added. A message similar to the following message is displayed:
/usr/sbin/luupgrade [52]:		3 patch-list-file: bad number
In the previous message, patch-list-file is the patch list file you specified for the luupgrade command to use to add patches.
Workaround: To add patches that specify a patch list file, perform the following steps.
  1. Become superuser.
  2. Mount the boot environment that you are patching.
    # lumount boot-envir-name mount-point
  3. Add the patches to the boot environment.
    # /usr/sbin/patchadd -R mount-point -M patch-path patch-list-file-name
    In the previous command, patch-path is the path name of a directory that contains patches to add. The patch-list-file-name is the file that contains the list of patches you are adding.
  4. Unmount the boot environment.
    # luumount boot-envir-name
