Solaris 9 12/02 Release Notes
CIM_ERR_LOW_ON_MEMORY Error Occurs When Trying to Add Data With WBEM (4312409)
The following error message is displayed when memory is low:
You cannot add more entries when the Common Information Model (CIM) Object Manager is low on memory. You must reset the CIM Object Manager Repository.
Workaround: To reset the CIM Object Manager Repository, follow these steps.
  1. Become superuser.
  2. Stop the CIM Object Manager.
    # /etc/init.d/init.wbem stop
  3. Remove the JavaSpacesTM log directory.
    # /bin/rm -rf /var/sadm/wbem/log
  4. Restart the CIM Object Manager.
    # /etc/init.d/init.wbem start
    Note -
    When you reset the CIM Object Manager Repository, you lose any proprietary definitions in your data store. You must recompile the MOF files that contain those definitions by using the mofcomp command. See the following example.
    # /usr/sadm/bin/mofcomp -u root -p root-password your-mof-file
