Solaris 9 12/02 Release Notes
Some com.sun Application Programming Interface Method Invocations Fail Under XML/HTTP Transport Protocol (4497393, 4497399, 4497406, 4497411)
If you choose to use the com.sun application programming interface rather than the javax application programming interface to develop your WBEM software, only CIM remote method invocation (RMI) is fully supported. Other protocols, such as XML/HTTP, are not guaranteed to work completely with the com.sun application programming interface.
The following table lists examples of invocations that execute successfully under RMI but fail under XML/HTTP.
Method Invocation
Error Message
CIMClient.close()
NullPointerException
CIMClient.execQuery()
CIM_ERR_QUERY_LANGUAGE_NOT_SUPPORTED
CIMClient.getInstance()
CIM_ERR_FAILED
CIMClient.invokeMethod()
XMLERROR: ClassCastException
