Solaris 9 12/02 Release Notes
Removing Solaris 9 12/02 Documentation Packages Might Unexpectedly Uninstall Some Solaris 9 12/02 Documentation Collections (4641961)
Some Solaris 9 12/02 documentation collections might be unexpectedly removed from your system if the following occurs.
  1. You install both the Solaris 9 12/02 Documentation 1 of 2 and 2 of 2 CDs on your system.
  2. You then use the prodreg utility or the Solaris 9 12/02 Documentation CD installer program to remove certain documentation packages.
The Solaris 9 12/02 Documentation CD 1 of 2 and 2 of 2 have three collections in common. If you remove the packages that contain these collections from either of the Solaris 9 12/02 Documentation 1 of 2 or 2 of 2 CD installations, the package is removed for both installations.
The following table lists the packages that might be removed unexpectedly.
Table 2-1 Solaris 9 12/02 Documentation Packages Contained on Both Solaris 9 12/02 Documentation CDs
HTML Package Names
PDF Package Names
Collection Description
SUNWaadm
SUNWpaadm
Solaris 9 System Administrator Collection
SUNWdev
SUNWpdev
Solaris 9 Developer Collection
SUNWids
SUNWpids
iPlanet Directory Server 5.1 Collection
Workaround: Choose one of the following workarounds.
