Solaris 9 12/02 Release Notes
Permission Problems Occur During Dynamic Reloading and Invocation of Applications (4756981)
If the Admin Server is owned by root and the server instance is owned by a nonroot user, permission problems might occur during dynamic reloading and invocation of applications.
Workaround: After deploying and redeploying the module or application (with or without the precompile option), change the directory owner from root to the nonroot user for the following directories. The nonroot user is the same as the instance owner.
The directory ownership change should be applied recursively to each of the directories, based on application type, in the following list:
  1. Become superuser.
  2. Type the following command for each of the directories that apply to your situation.
    # chown -R non-root-instance-owner directory-name
