Solaris 9 12/02 Release Notes
Server Ignores Case-Sensitive Syntax When Normalizing DN Attributes (4630941)
You cannot use the LDAP naming services to create automount path names that are identical, except for case results in nonunique path names. The directory server does not allow creation of entries if the naming attribute is defined with case-sensitive syntax and an entry already exists with the same name but a different case.
Note -
/home/foo and /home/Foo paths cannot coexist.
For example, if entry attr=foo,dc=mycompany,dc=com exists, the server does not allow the creation of attr=Foo,dc=mycompany,dc=com. A corollary of this problem is that when LDAP naming services are used, automount path names have to be unique, regardless of their case.
Workaround: None.
