Solaris 9 12/02 Release Notes
Accessing an Oracle 9.1 Database With an Oracle 9.2 Client Might Cause Data Corruption (4707531)
If you use an Oracle 9.2 client to access an Oracle 9.1 database, data corruption might occur when a number column follows a timestamp column.
The problem might be caused by using the ojdbc14.jar file with an Oracle 9.1 database. Applying the patch might assist in addressing the situation on Solaris 32-bit machines, that run an Oracle 9.1 database. This JDBCTM driver is for Oracle working with JDKTM 1.4.
Workaround: Obtain the patch that Oracle might make available from the Oracle Web site for Bug 2199718 and apply it to your server.
