Solaris 9 12/02 Release Notes
SPARC: dtmail Crashes When Launched From the Command Line if FontList Option Is Specified (4677329)
dtmail crashes after connecting with the IMAP server if the FontList option is specified when dtmail is launched from the command line. See the following example.
/usr/dt/bin/dtmail -xrm "Dtmail*FontList: -*-r-normal-*:"
The following error message is displayed.
Segmentation Fault
This problem occurs in both the C and ja locales.
Workaround: Do not specify the FontList option when you launch dtmail from the command line.
