If you have difficulty locating the mouse pointer on the screen, you can enable an option to highlight the pointer when you press the Control key. To enable this option, click on the Cursors tab in the Mouse Preferences dialog, then select the Show position of cursor when the Control key is pressed option. When you press Control, the system displays an animation around the pointer to highlight the pointer.
