GNOME 2.0 Desktop for the Solaris Operating Environment Accessibility Guide
Navigating Your Workspaces
A workspace is a discrete area in which you can work. You can have many workspaces on your desktop and you can switch from one workspace to another. Each workspace can contain different windows and processes. The following table lists the keyboard shortcuts that you can use to navigate workspaces.
Ctrl+ Alt + arrow keys
Give focus to the next or previous workspace. This keyboard shortcut displays a popup window with icons that represent the workspaces. Press and hold Ctrl+Alt and continue to press the arrow keys to switch the focus between the workspaces.
You can customize this keyboard shortcut.
Shift+ Alt + arrow keys
Move the window that has focus to the next or previous workspace.
