GNOME 2.0 Desktop for the Solaris Operating Environment Accessibility Guide
To Give Focus to a Window
Before you can use or modify a window, you must give focus to the window. The following table lists the keyboard shortcuts that you can use to give focus to a window.
Keys
Function
Alt+ Tab
Display a popup window with icons that represent each window. Press-and-hold Alt and continue to press Tab to move through the windows until you reach the window to which you want to give focus.
Alt+Esc
Raise each window in turn until you reach the window to which you want to give focus.
