When a window has focus, you can move the window around the screen. The following table lists the keyboard shortcuts that you can use to move a window.
Keys |
Function |
Alt+F7 |
Start the move operation. |
arrow keys |
Move the window 10 pixels at a time in the direction of the arrow key. |
Ctrl+ arrow keys |
Move the window one pixel at a time in the direction of the arrow key. |
Shift + arrow keys |
Move the window in the direction of the arrow key to align it with the edge of the nearest window, panel, or screen edge. |
spacebar |
Complete the move operation and leave the window in the current position. |
Esc |
Cancel the move operation and restore the window to the original position. |
