The following table lists the essential keyboard shortcuts that you can use to navigate dialogs.
Keys |
Function |
Alt+access key |
Activate or select a control. |
Tab |
Give focus to the next control. |
Ctrl+ Page Up |
Move to the next tabbed section of the dialog, if the dialog contains tabbed sections. |
Ctrl+Page Down |
Move to the previous tabbed section of the dialog, if the dialog contains tabbed sections. |
Esc |
Close the dialog. |
Return |
Perform the default action for the dialog. The default action is usually to apply the changes and close the dialog. |
