GNOME 2.0 Desktop for the Solaris Operating Environment Accessibility Guide
To Navigate Text Boxes
Text boxes are controls in which you type text.
Figure 3–6 Sample Single Line Text Box
Graphic
The following table lists the keyboard shortcuts that you can use to navigate a single line text box.
Keys
Function
left arrow
Position the cursor one character to the left.
right arrow
Position the cursor one character to the right.
Ctrl+left arrow
Position the cursor at the start of the current word. Press-and-hold Ctrl and continue to press left arrow to position the cursor at the start of the previous word.
Ctrl+right arrow
Position the cursor at the end of the current word. Press-and-hold Ctrl and continue to press right arrow to position the cursor at the end of the next word.
Home
Position the cursor at the start of the line.
End
Position the cursor at the end of the line.
Shift+ left arrow or right arrow
Select one character at a time to the left or right of the cursor.
Shift+Ctrl+left arrow or right arrow
Select one word at a time to the left or right of the cursor.
Shift+ Home
Select all text to the left of the cursor.
Shift+End
Select all text to the right of the cursor.
Ctrl+A
Select all text in the text box.
In addition to the keyboard shortcuts listed in the previous table, use the keyboard shortcuts in the following table to navigate multi-line text boxes.
Keys
Function
Page Up
Position the cursor at the top of the current view. Press Page Up again to position the cursor at the top of the previous view.
Page Down
Position the cursor at the end of the current view. Press Page Down again to position the cursor at the end of the previous view.
Ctrl+up arrow
Position the cursor at the start of the current paragraph. Press-and-hold Ctrl and continue to press up arrow to position the cursor at the start of the previous paragraph.
Ctrl+down arrow
Position the cursor at the end of the current paragraph. Press-and-hold Ctrl and continue to press down arrow to position the cursor at the end of the next paragraph.
Ctrl+Page Up
Position the cursor one view width to the left.
Ctrl+Page Down
Position the cursor one view width to the right.
Ctrl+Home
Position the cursor at the start of the text box.
Ctrl+End
Position the cursor at the end of the text box.
Ctrl+Tab
Give focus to the next control on the dialog.
Shift+ Page Up
Select the text to the start of the current view. Press-and-hold Shift and continue to press Page Up to extend the selection to the start of the previous view.
Shift+Page Down
Select the text to the end of the current view. Press-and-hold Shift and continue to press Page Down to extend the selection to the end of the next view.
Shift+Home
Select the text to the start of the line.
Shift+End
Select the text to the end of the line.
Shift+Ctrl+up arrow
Select the text to the start of the paragraph, then to the start of the previous paragraph.
Shift+ Ctrl+down arrow
Select the text to the end of the paragraph, then to the end of the next paragraph.
Shift+ Ctrl+Home
Select the text to the start of the text box.
Shift+ Ctrl+End
Select the text to the end of the text box.
