GNOME 2.0 Desktop for the Solaris Operating Environment Accessibility Guide
To Navigate Drop-Down Combination Boxes
A drop-down combination box is a text box with a drop-down list box attached.
Figure 3–9 Sample Drop-Down Combination Box
Graphic
When the text box has focus, use the keyboard shortcuts that are listed in To Navigate Text Boxes to navigate the text box area. When the text box has focus, you can also use the keyboard shortcuts in the following table to navigate the drop-down list area.
Keys
Function
up arrow
Select the previous item from the drop-down list without displaying the list.
down arrow
Select the next item from the drop-down list without displaying the list.
Ctrl+ down arrow
Open the drop-down list.
When the drop-down list has focus, you can use the keyboard shortcuts that are listed in the following table to navigate the drop-down list.
Keys
Function
up arrow
Select the previous list item.
down arrow
Select the next list item.
Home
Select the first item on the list.
End
Select the last item on the list.
Page Up
Select the item at the top of the current list view.
Page Down
Select the item at the bottom of the current list view.
spacebar
Accept the current selection and close the drop-down list.
Ctrl+Page Up
Scroll to the left of the list, if required.
Ctrl+Page Down
Scroll to the right of the list, if required.
