System Administration Guide: Security Services
Chapter 10 Using PAM
This chapter covers the Pluggable Authentication Module (PAM) framework. PAM provides a method to “plug in” authentication services and provides support for multiple authentication services.
PAM (Overview)
The Pluggable Authentication Module (PAM) framework lets you “plug in” new authentication technologies without changing system entry services, such as login, ftp, telnet, and so on. You can also use PAM to integrate UNIX login with other security mechanisms like Kerberos. Mechanisms for account, session, and password management can also be “plugged in” by using this framework.
Benefits of Using PAM
The PAM framework allows you to configure the use of system entry services (ftp, login, telnet, or rsh, for example) for user authentication. Some benefits that PAM provides are as follows:
PAM Components
The PAM software consists of a library, several modules, and a configuration file. New versions of several commands or daemons that take advantage of the PAM interfaces are also included.
The following figure illustrates the relationship between the applications, the PAM library, the pam.conf file, and the PAM modules.
Figure 10–1 How PAM Works
Diagram shows how the PAM library is situated between the PAM modules and the applications that use the modules.
The applications, such as ftp, telnet, and login, use the PAM library to call they configuration policy. The pam.conf file defines which modules to use, and in what order the modules are to be used with each application. Responses from the modules are passed back through the library to the application.
The following sections describe the relationship between the PAM components and the applications.
PAM Library
The PAM library provides the framework to load the appropriate modules and to manage the stacking process. The PAM library provides a generic structure to which all of the modules can plug in. See the pam.3PAM XREF man page for more information.
Password-Mapping Feature
The stacking feature can require that a user remembers several passwords. With the password-mapping feature, the primary password is used to decrypt the other passwords. The user does not need to remember or enter multiple passwords. The other option is to synchronize the passwords across each authentication mechanism. This strategy could increase the security risk, because the mechanism security is limited by the least secure password method that is used in the stack.
Changes to PAM for the Solaris 9 Release
The Solaris 9 release includes several enhancements to the PAM service. The following list highlights the most important changes:
Changes to PAM for the Solaris 9 Update 2 Release
Update 2 includes a new binding control flag. This flag provides the ability to skip additional authentication if the service module returns success and if no preceding required modules have failed. The control flag is documented in the pam.conf(4) man page and in PAM Control Flags.
PAM (Tasks)
This section discusses some tasks that might be required to make the PAM framework fully functional. In particular, you should be aware of some security issues that are associated with the PAM configuration file.
PAM (Task Map)
Task
Description
For Instructions
Plan for your PAM Installation
 Consider configuration issues and make decisions about them before you start the software configuration process.Planning for PAM
Add new PAM modules
 Sometimes, site-specific modules must be written and installed to cover requirements that are not part of the generic software. This procedure covers the installation process.How to Add a PAM Module
Block access through ~/.rhosts
Steps to further increase security by preventing access through ~/.rhosts.How to Prevent Unauthorized Access From Remote Systems With PAM
Initiate error reporting
Steps to start the reporting of PAM error messages through syslog.How to Initiate PAM Error Reporting
Planning for PAM
When you are deciding how best to use PAM in your environment, start by focusing on these issues:
Here are some suggestions to consider before you change the PAM configuration file:
  1. Become superuser or assume an equivalent role.
  2. Determine which control flags and which other options should be used.
    Refer to PAM Modules information on the modules.
  3. Copy the new module to /usr/lib/security/sparcv9.
    In the Solaris 8 release, the module should be copied to /usr/lib/security.
  4. Set the permissions so that the module file is owned by root and that permissions are 555.
  5. Edit the PAM configuration file, /etc/pam.conf, and add this module to the appropriate services.
Verification
You must test before the system is rebooted in case the configuration file is misconfigured. Run rlogin, su, and telnet before you reboot the system. The service might be a daemon that is spawned only once when the system is booted. Then you must reboot the system before you can verify that the module has been added.
Remove the rlogin auth rhosts_auth.so.1 entry from the PAM configuration file. This step prevents the reading of the ~/.rhosts files during an rlogin session. Therefore, this step prevents unauthenticated access to the local system from remote systems. All rlogin access requires a password, regardless of the presence or contents of any ~/.rhosts or /etc/hosts.equiv files.
Note –
To prevent other unauthenticated access to the ~/.rhosts files, remember to disable the rsh service. The best way to disable a service is to remove the service entry from the /etc/inetd.conf file. Changing the PAM configuration file does not prevent the service from being started.
  1. Edit the /etc/syslog.conf file to add any of the following entries for PAM error reporting:
    • auth.alert – Messages about conditions that should be fixed immediately
    • auth.crit – Critical messages
    • auth.err – Error messages
    • auth.info – Informational messages
    • auth.debug – Debugging messages
  2. Restart the syslog daemon, or send a SIGHUP signal to the daemon to activate the PAM error reporting.
Example—Initiating PAM Error Reporting
In the following example, all alert messages are displayed on the console. Critical messages are mailed to root. Informational and debug messages are added to the /var/log/pamlog file.
auth.alert	/dev/console
auth.crit	'root'
auth.info;auth.debug	/var/log/pamlog
Each line in the log contains a time stamp, the name of the system that generated the message, and the message. The pamlog file is capable of logging a large amount of information.
PAM (Reference)
PAM uses run-time pluggable modules to provide authentication for system entry services. A stacking feature is provided to let you authenticate users through multiple services. Also provided is a password-mapping feature to not require that users remember multiple passwords.
PAM Modules
Every PAM module implements a specific mechanism. When you set up PAM authentication, you need to specify both the module and the module type, which defines what the module does. More than one module type, such as auth, account, session, or password, can be associated with each module.
The following table describes every PAM module, and includes the module name and the module file name. The path of each module is determined by the instruction set that is available in the Solaris release that is installed. The default path to the modules is /usr/lib/security/$ISA. The value for $ISA could be sparc or i386. See the isalist(5) man page for more information.
Table 10–1 PAM Modules
Module Name and Module File Name
Description
authtok_check
pam_authtok_check.so.1
Provides support for password management. This module performs various checks on passwords. Those check are for the length of the password, for circular shift of the login name, for password complexity, and for the amount of variation between new passwords and old passwords. See pam_authtok_check(5) for more information.
authtok_get
pam_authtok_get.so.1
Provides password prompting for authentication and password management. See pam_authtok_get(5) for more information.
authtok_store
pam_authtok_store.so.1
Provides support for authentication only. This module updates the authentication token for the user. After the successful update, the module stores the token in the specified repository or default repository. See pam_authtok_store(5) for more information.
dhkeys
pam_dhkeys.so.1
Provides support for Diffie-Hellman key management in authentication. This module supports Secure RPC authentication and Secure RPC authentication token management. See pam_dhkeys(5) for more information.
dial_auth
pam_dial_auth.so.1
Can only be used for authentication. This module uses data that is stored in the /etc/dialups and /etc/d_passwd files for authentication. This module is mainly used by the login command. See pam_dial_auth(5) for more information.
krb5
pam_krb5_auth.so.1
Provides support for authentication, account management, session management, and password management. Kerberos credentials are used for authentication. See pam_krb5(5) for more information.
ldap
pam_ldap.so.1
Provides support for authentication and password management. Data from an LDAP server are used for authentication. See pam_ldap(5) for more information.
projects
pam_projects.so.1
Provides support for account management. See pam_projects(5) for more information.
rhosts_auth
pam_rhosts_auth.so.1
Can only be used for authentication. This module uses data that is stored in the ~/.rhosts and /etc/host.equiv files through the ruserok() routine. This module is mainly used by the rlogin and rsh commands. See pam_rhosts_auth(5) for more information.
roles
pam_roles.so.1
Provides support for account management only. The RBAC user_attr database determines which roles a user can assume. See pam_roles(5) for more information.
sample
pam_sample.so.1
Provides support for authentication, account management, session management, and password management. Used for testing. See pam_sample(5) for more information.
smartcard
pam_smartcard.so.1
Provides support for authentication only. See pam_smartcard(5) for more information.
unix
pam_unix.so.1
Provides support for authentication, account management, session management, and password management. Any of the four module type definitions can be used with this module. This module uses UNIX passwords for authentication.
In the Solaris environment, the selection of appropriate name services to get password records is controlled through the /etc/nsswitch.conf file. See pam_unix(5) for more information.
unix_account
pam_unix_account.so.1
Provides support for account management. This module retrieves password aging information from the repository that is specified in the nsswitch.conf file. Then the module verifies that the password and the user's account have not expired. See pam_unix_account(5) for more information.
unix_auth
pam_unix_auth.so.1
Provides support for authentication. This module verifies the password that is contained in the PAM handle. The module checks that the user's password matches the password in the specified repository or default repository. See pam_unix_auth(5) for more information.
unix_session
pam_unix_session.so.1
Provides support for session management. This module initiates session management by updating the /var/adm/lastlog file. See pam_unix_session(5) for more information.
For security reasons, these module files must be owned by root and must not be writable through group or other permissions. If the file is not owned by root, PAM does not load the module.
PAM Module Types
You need to understand the PAM module types because the types define the interface to the module. Here are the four types of run-time PAM modules:
PAM Configuration File
The PAM configuration file, /etc/pam.conf, determines the authentication services to be used, and the order in which the services are used. This file can be edited to select authentication mechanisms for each system entry application.
PAM Configuration File Syntax
The PAM configuration file consists of entries with the following syntax:
service_name module_type control_flag module_path module_options
service_name
Is the name of the service, for example, ftp, login, telnet.
module_type
Is the module type for the service. For more information, see PAM Module Types.
control_flag
Determines the continuation or failure behavior for the module.
module_path
Specifies the path to the library object that implements the service.
module_options
Specifies the options that are passed to the service modules.
You can add comments to the pam.conf file by starting the line with a # (pound sign). Use white spaces or tabs to delimit the fields.
Note –
An entry in the PAM configuration file is ignored if one of the following conditions exists: the line has less than four fields, an invalid value is given for module_type or control_flag, or the named module does not exist.
Valid Service Names for PAM
The following table lists:
Some module types are not appropriate for each service. For example, the password module type is appropriate for only the passwd command. Also, because the passwd command is not concerned with authentication, no auth module type is associated with the service.
Table 10–2 Valid Service Names for the /etc/pam.conf File
Service Name
Daemon or Command
Applicable Module Types
cron
/usr/sbin/cron
auth, account
dtlogin
/usr/dt/bin/dtlogin
dtsession
/usr/dt/bin/dtsession
auth
ftp
/usr/sbin/in.ftpd
init
/usr/sbin/init
session
login
/usr/bin/login
passwd
/usr/bin/passwd
password
ppp
/usr/bin/ppp
rexd
/usr/sbin/rpc.rexd
account, session
rlogin
/usr/sbin/in.rlogind
rsh
/usr/sbin/in.rshd
sac
/usr/lib/saf/sac
session
ssh
/usr/bin/ssh
su
/usr/bin/su
auth, account
telnet
/usr/sbin/in.telnetd
ttymon
/usr/lib/saf/ttymon
session
uucp
/usr/sbin/in.uucpd
PAM Control Flags
To determine the continuation or failure behavior from a module, you must select a control flag for each entry in the PAM configuration file, /etc/pam.conf. Each module in a stack can determine the success or failure of the request.
Continuation behavior defines if any following modules are checked. Depending on the response from a particular module, you can decide to skip any additional modules.
Failure behavior defines how error messages are logged or reported. Failures are either optional or required. A required failure causes that request to fail, even if other modules succeed. An optional failure does not always cause the request to fail.
Even though these flags apply to all module types, the following explanation assumes that these flags are being used for authentication modules. The control flags are as follows:
More information about these control flags is provided in the following section, which describes the default /etc/pam.conf file.
Generic pam.conf File
The generic /etc/pam.conf file specifies the following actions:
  1. When the login command is run, authentication must succeed for the pam_authtok_get, pam_dhkeys, pam_auth_unix, and the pam_dial_auth modules.
  2. For the rlogin command, authentication through the pam_authtok_get, pam_dhkeys, and pam_auth_unix modules must succeed if authentication through pam_rhost_auth fails.
  3. The sufficient control flag indicates that for the rlogin command, the successful authentication that is provided by the pam_rhost_auth module is sufficient. The next entry is ignored.
  4. Most of the other commands that require authentication require successful authentication through the pam_authtok_get, pam_dhkeys, and pam_auth_unix modules.
  5. For the rsh command, authentication through the pam_rhost_auth module is flagged as sufficient. No other authentication is required if authentication through the pam_rhost_auth module succeeds.
The OTHER service name allows a default to be set for any other commands that require authentication and are not included in the file. The OTHER option simplifies administration of the file, since many commands that are using the same module can be covered by using only one entry. Also, the OTHER service name, when used as a “catch-all,” can ensure that each access is covered by one module. By convention, the OTHER entry is included at the bottom of the section for each module type.
Normally, the entry for the module_path is “root-relative.” If the file name that you enter for module_path does not begin with a slash (/), the path /usr/lib/security/$ISA precedes the file name. A full path name must be used for modules that are located in other directories. The values for the module_options can be found in the man pages for the module. For example, the UNIX module is covered in the pam_unix(5) man page.
login   auth required           pam_authtok_get.so.1
login   auth required           pam_dhkeys.so.1
login   auth required           pam_unix_auth.so.1
login   auth required           pam_dial_auth.so.1
In this example, the login service specifies authentication through all four authentication modules. A login command fails if any one of the modules returns an error.
