System Administration Guide: Security Services
Securing Machines (Task Map)
A computer is as secure as its weakest point of entry. The following task map shows the areas that you should monitor and secure.
Task
Description
For Instructions
Display a user's login status
Use the logins command to view a user's login status information.
How to Display a User's Login Status
Find users who do not have passwords
Use the logins command to find only those users whose accounts do not require a password.
How to Display Users Without Passwords
Disable logins temporarily
Deny user logins to a machine as part of system shutdown or routine maintenance.
How to Temporarily Disable User Logins
Provide strong password encryption
Specify algorithms for password encryption.
How to Specify an Algorithm for Password Encryption
Provide strong password encryption with a name service
Specify algorithms for password encryption when you are using a name service.
How to Specify a New Password Algorithm for an NIS+ Domain
How to Specify a New Password Algorithm for an NIS Domain
How to Specify a New Password Algorithm for an LDAP Domain
Add new password encryption module
Add third-party algorithms.
How to Install a Password Encryption Module From a Third Party
Save failed login attempts
Create a log of users who failed to provide the correct password after five attempts.
How to Save Failed Login Attempts
Create a dial-up password
Require an additional password for users who log in remotely through a modem or dial-up port.
How to Create a Dial-up Password
Disable dial-up entry temporarily
Prevent users from dialing in remotely through a modem or port.
How to Temporarily Disable Dial-up Logins
Monitor who is using the su command
Read the sulog file on a regular basis.
How to Monitor Who Is Using the su Command
Display superuser activity on the console
Monitor superuser access attempts.
How to Display Superuser (root) Access Attempts to the Console
Prevent remote access to the console as superuser
Require remote users to log in with their username and then become root.
How to Prevent Remote Login by Superuser (root)
Prevent users from changing machine parameters
Prevent users from changing PROM settings.
How to Require a Password for Hardware Access
Disable the abort sequence
Prevent users from accessing the PROM.
How to Disable or Enable a System's Abort Sequence
