Solaris 9 Installation Guide
Customizing the Solaris Installation on the Master System
After you install the Solaris operating environment on the master system by using any of the Solaris installation methods, you can add or delete software and modify system configuration information as necessary.
Further customization can be done when creating the archive. For example, you can exclude large data files that you might not want in the archive. For an overview, see Customizing an Archive's Files and Directories.
To update a clone system, you can create a differential archive, see Planning the Creation of a Solaris Flash Archive.
