Solaris 9 Installation Guide
Splitting a Solaris Flash Archive
You can split an archive into sections, which enables you to modify some sections, add new sections, or delete sections. After you have modified the sections, you need to merge the sections to create an new archive. For example, you might want to add a User-Defined section or modify the Archive Identification section. Do not modify the Archive Files section or you compromise the integrity of the archive.
The flar split command splits a Solaris Flash archive into sections. The flar command copies each section into a separate file in the current directory or specified directory. The files are named after the sections, for example, the archive cookie is saved in a file that is named cookie. You can specify that the flar split command save only one section. The syntax of the command is as follows:
flar split[-d dir] [-u section] [-f archive] [-S section] [-t [-p posn] [-b blocksize]] filename
-d dir
Retrieves the sections to copy from dir, rather than from the current directory
-u section
  • If you use this option, flar copies the Cookie, Identification, Archive, and section sections. You can specify a single section name or a space-separated list of section names.
  • If you do not use this option, flar copies the Cookie, Identification, and Archive sections only.
-f archive
Extracts the Archive section into a directory that is named archive, rather than placing it in a file with the name archive
-S section
Only copies the section that is named section from the archive. This section is user-defined.
Example 19–1 Splitting an Archive
In the following example, archive1.flar is split into three files:
# flar split archive1.flar
After the archive is split, you can modify the Archive Identification section or add a User-Defined section. The sections can then be merged to recreate the archive.
