Solaris 9 Installation Guide
Updating Clone Systems With a Solaris Flash Differential Archive
If you have a clone system and want to update it, you can create a differential archive that contains only the differences between two images, the unchanged master image and an updated master image. When you update a clone system with a differential archive, only the files that are in the differential archive are changed. You use the Solaris Flash custom JumpStart installation method to install an update on a clone system. An update is a five-part process.
  1. Prepare the master system with changes. Before changes are made, the master system should be running a duplicate of the original archive.
    Note –
    If the master system is not running a duplicate of the original archive, the differences between the two system images might result in a large differential archive. Consequently, installing the differential archive could be time consuming. Use an initial installation with a full archive in this case.
  2. (Optional) Prepare customization scripts to reconfigure or customize the clone system before or after installation.
  3. Mount the directory of a copy of the saved-unchanged master image. This second image is to be used to compare the two system images. Access the image by the following methods:
    • Mounted from a Solaris Live Upgrade boot environment
    • Mounted from a clone system over NFS
    • Restored from backup using the ufsrestore command.
  4. Create the differential archive with the -A option of the flar create command.
  5. Install the differential archive on clone systems with custom JumpStart.
Figure 17–2 shows the creation and installation of a differential archive. A master image is updated with some modifications. These modifications could be as simple as the addition, reconfiguration, or deletion of a few files, or as complex as propagating patches. The updated master image is compared to the unchanged master image. The differences between the two images become the differential archive. The archive can be used to update other clone systems that are currently using the unchanged master image. If the clone system has already been modified or is not running the unchanged master image, the update fails. If you have many changes to make on the clone systems, you can do an initial installation at any time.
Figure 17–2 Solaris Flash Update
The context describes the illustration.
