Table 28–2 provides a quick way to determine which keywords you can use, based on your installation scenario. Unless otherwise noted in the keyword descriptions, the keyword can only be used with the initial installation option.
Table 28–2 Overview of Profile Keywords
Installation Scenarios |
Profile Keywords |
Standalone System (Non-Networked) |
Standalone System (Networked) or Server |
OS Server |
Upgrade |
Upgrade With Disk Space Reallocation |
archive_location (Installing Solaris Flash archives) |
backup_media |
boot_device |
client_arch |
client_root |
client_swap |
cluster (adding software groups) |
cluster (adding or deleting clusters) |
dontuse |
fdisk (x86 only) |
filesys (mounting remote file systems) |
filesys (creating local file systems) |
forced_deployment (installing Solaris Flash differential archives) |
geo |
install_type |
isa_bits |
layout_constraint |
local_customization (installing Solaris Flash archives) |
locale |
no_master_check (installing Solaris Flash differential archives) |
no_content_check (installing Solaris Flash differential archives) |
num_clients |
package |
partitioning |
root_device |
system_type |
usedisk |
