Solaris 9 Installation Guide
Checking System Patch Levels
Solaris Live Upgrade software is designed to be installed and to be run on multiple versions of the Solaris operating environment. Correct operation of Solaris Live Upgrade requires the latest recommended patches and security patches for a given OS version. Consult for the correct revision level for a patch cluster for the release of Solaris that you are running.
