Solaris 9 Installation Guide
Memory Requirement
To install or upgrade to the Solaris operating environment, the suggested memory size is 128 Mbytes or greater.
Note –
Some optional installation features are enabled only when sufficient memory is present. For example, if you install from a DVD with insufficient memory, you install through the Solaris Web Start installation program's command-line interface, not through the Web Start graphical user interface.
