Solaris 9 Installation Guide
filesys Profile Keyword (Creating Local File Systems)
filesys slice size [[file_system optional_parameters]]
By using filesys with the values that are listed, the JumpStart program creates local file systems during the installation. You can specify filesys more than once.
slice – Use one of the following values:
size – Use one of the following values:
file_system – The file_system value is optional and used when slice is specified as any or cwtxdysz. If file_system is not specified, unnamed is set by default. If unnamed is set, you cannot specify the optional_parameters value. Use one of the following values:
optional_parameters – Use one of the following values:
