Solaris 9 Installation Guide
num_clients Profile Keyword
num_clients client_num
When a server is installed, space is allocated for each diskless client's root (/) and swap file systems. num_clients defines the number of diskless clients, client_num, that a server supports. If you do not specify num_clients in the profile, five diskless clients are allocated by default.
Note –
You can use num_clients only when system_type is specified as server.
