If you upgrade from the Solaris 9 operating environment to the Solaris 9 9/02, Solaris 9 12/02, or Solaris 9 4/03 release, the upgrade does not reregister existing Managed Object Format (MOF) files. During the upgrade, the old /var/sadm/wbem/logr directory is saved as the /var/sadm/wbem/logru3 directory. The registered MOF files are not reregistered after the upgrade. As a result, Solaris Management Console applications that depend on MOF files will fail.
The following error message is displayed when you use the console Mounts and Disks tools:
CIM_ERR_NOT_FOUND |
Workaround: Manually register the missing MOF files. The MOF files are available in the /var/sadm/wbem/logru3 directory. Complete the following steps:
Become superuser.
Manually register the MOF files.
# /usr/sadm/bin/mofreg -r tag mof-file |
where tag is the directory located in the /var/sadm/wbem/logru3/unregDir/ directory and mof–file is the MOF file located in the tag directory.
For example:
# /usr/sadm/bin/mofreg -r svm \ /var/sadm/wbem/logru3/unregDir/svm/svm/Solaris_Vm1.0.mof |
Stop the WBEM server.
# /etc/init.d/init.wbem stop |
Restart the WBEM server.
# /etc/init.d/init.wbem start |
