When installing in single-user mode, do not use the exit command when you are done. Use the reboot command. If the exit command is used instead of the reboot command, the following occurs:
The system is brought to init 3, and you cannot log in until the system is rebooted.
No other users can log in until the system is rebooted.
pam_projects.so.1 dumps core when any user or process tries to log in. The following message is displayed.
NOTICE: core_log: in.rshd[1479] core dumped: /var/crash/core.in.rshd.1479 |
If a process attempts to access the pam_projects.so.1 module, load module messages are displayed on the system console. A message similar to the following is displayed.
cron[1433]: load_modules: can not open module /usr/lib/security/pam_projects.so.1 |
These messages are also displayed if MU3 is installed in multiuser mode. In both cases, the messages are no longer displayed after the system is rebooted.
Workaround: If the exit command is used after installing in single-user mode, reboot the system.
If the exit command is used after installing in multiuser mode and no root users remain logged in, reboot the system.
