If you have created a new boot environment with Solaris Live Upgrade, you cannot install a Solaris Flash differential archive on the new boot environment by using the luupgrade command. The following error message is displayed:
/usr/sbin/luupgrade[607]: ludo: not found |
A Solaris Flash differential archive is a minor update to the operating environment on a boot environment that has been upgraded with a Solaris Flash archive.
Workaround: To enable the use of the luupgrade command to install a differential archive, edit the /etc/default/lu file. Change the existing PATH variable setting so that /etc/lib/lu is the first component in the path.
Do not use this path:
PATH=/etc:/sbin:/usr/bin:/usr/sbin:$PATH |
Change the path to the following:
PATH=/etc/lib/lu:/etc:/sbin:/usr/bin:/usr/sbin:$PATH |
For more information, see the Solaris 9 Installation Guide.
