Solaris 9 8/03 Release Notes
SPARC: Administration Interface Reports Verifier Error When Viewing Persistence Manager Factory Resource Created From the Command Line (4733109)
A verifier error is reported for a Persistence Manager Factory resource that was created by using the command-line interface. The following error is displayed when the resource is viewed in the Sun ONE Application Server Administration interface:
ArgChecker Failure: Validation failed for jndiName: object must be non-null
Workaround: Perform the following steps to create a new Persistence Management Factory resource:
  1. Create a jdbc-connection pool with data source information to connect to a database.
  2. Create a jdbc-resource to make the connection pool available via a Java Naming and Directory InterfaceTM (J.N.D.I.) lookup.
  3. Create a persistence-management resource with the jdbc-resource that was created in Step 2.
