If the UFS noatime and logging mount options are used together, the file system can become corrupted because an inode is not being written. This failure can result in the display of the following messages:
/mnt: unexpected allocated inode 1783, run fsck(1M)... /zoot: unexpected free inode 5674, run fsck(1M)... |
Workaround: Perform the following steps:
Determine which file systems are using the noatime and logging mount options.
% mount | grep noatime | grep logging |
Edit /etc/vfstab to remove the noatime option from all file systems that use the logging option.
Unmount and run the fsck command against all the file systems that were mounted by using the logging and noatime mount options.
Run the fsck command against any currently unmounted file systems that were previously mounted with the logging and noatime mount options.
The fsck command might display messages that are similar to the following:
8016 DUP I=646 EXCESSIVE DUP BLKS I=7404 INCORRECT BLOCK COUNT I=7407 DUP/BAD I=646 OWNER=root MODE=100644 ZERO LENGTH DIRECTORY I=3807 BAD/DUP FILE I=575 OWNER=root MODE=100644 BAD/DUP DIRECTORY I=3807 OWNER=root MODE=40755 LINK COUNT DIR I=3806 OWNER=root MODE=40755 LINK COUNT FILE I=25084 OWNER=host1 MODE=100644 FREE BLK COUNT(S) WRONG IN SUPERBLK |
