IPv6 Administration Guide
For More Information About 6to4 Routing
Configuring 6to4 routing is a straightforward task. The next table shows where to go for 6to4 configuration tasks and technical details.
Task or Detail
For Information
To configure a 6to4 router
How to Configure a 6to4 Router
To configure a 6to4 relay router
How to Configure a 6to4 Tunnel to a 6to4 Relay Router
For 6to4 modifications to ifconfig
IPv6 Extensions to the ifconfig Utility
For information about the 6to4relay command
6to4relay Command
For details about 6to4 site topology
Participants in a 6to4 Tunnel
For details about 6to4 addressing
6to4-Derived Addressing
For detailed information about 6to4 relay routers
Considerations for Tunnels to a 6to4 Relay Router
