IPv6 Administration Guide
6to4relay Command
6to4 tunneling enables communication between isolated 6to4 sites. However, to transfer packets with a native, non-6to4, IPv6 site, the 6to4 router must establish a tunnel with a 6to4 relay router. The 6to4 relay router then forwards the 6to4 packets to IPv6 network and ultimately, the native IPv6 site. If your 6to4 site must exchange data with a native IPv6 site, you use the 6to4relay command to enable the appropriate tunnel.
Because the use of relay routers is insecure, tunneling to a relay router is disabled by default in the Solaris operating system. Carefully consider the issues that are involved in creating a tunnel to a 6to4 relay router before deploying this scenario. For detailed information on 6to4 relay routers, refer to Considerations for Tunnels to a 6to4 Relay Router. Should you decide to enable 6to4 relay router support, you can find the related procedures in How to Configure a 6to4 Tunnel to a 6to4 Relay Router.
Syntax of 6to4relay
The 6to4relay command has the following format:
6to4relay -e [-a IPv4-address] -d -h
-e
Enables support for tunnels between the 6to4 router and an anycast 6to4 relay router. The tunnel endpoint address is then set to 192.88.99.1, the default address for the anycast group of 6to4 relay routers.
-a IPv4–address
Enables support for tunnels between the 6to4 router and a 6to4 relay router with the specified IPv4–address.
-d
Disables support for tunneling to the 6to4 relay router, the default for the Solaris operating system.
–h
Displays usage help for 6to4relay.
For more information, refer to the 6to4relay(1M) man page.
Examples—Displaying the Status of 6to4 Relay Router Support
6to4relay, without arguments, shows the current status of 6to4 relay router support. The first example shows the default.
# /usr/sbin/6to4relay
6to4relay:6to4 Relay Router communication support is disabled
If relay router support is enabled, 6to4relay displays the following output.
6to4relay:6to4 Relay Router communication support is enabled
IPv4 destination address of Relay Router=192.88.99.1
If you specified the -a option and IPv4 address to 6to4relay, the IPv4 address that you gave with -a is displayed instead of 192.88.99.1.
6to4relay does not report successful execution of the –d, –e, and -a IPv4 address options. However, 6to4relay does display any errors that might have occurred when you ran these options.
