IPv6 Administration Guide
Configuring IP in IP Tunnels Task Map
Table 2–3 Configuring IP in IP Tunnels Task Map
Task
Description
Instructions
Manually configuring IPv6 over IPv4 tunnels
Shows the entries required for the hostname6.ip.tunn file.
How to Configure IPv6 Over IPv4 Tunnels
Automatically configuring IPv6 over IPv4 tunnels (6to4 tunnels)
Shows entries required for the hostname6.ip.6to4tun file.
How to Configure a 6to4 Router
Configuring IPv6 over IPv6 tunnels
Shows the entries required for the hostname6.ip.6.tunn file.
How to Configure IPv6 Over IPv6 Tunnels
Configuring IPv4 over IPv6 tunnels
Shows the entries required for the hostname.ip6.tunn file.
How to Configure IPv4 Over IPv6 Tunnels
Configuring IPv4 over IPv4 tunnels
Shows the entries required for the hostname.ip.tunn file.
How to Configure IPv4 Over IPv4 Tunnels
Configuring a tunnel between a 6to4 router and a 6to4 relay router
Describes how to enable a tunnel to a 6to4 relay router by using the 6to4relay command.
How to Configure a 6to4 Tunnel to a 6to4 Relay Router
Configuring your router to advertise over tunneling interfaces
Shows the entries required for the /etc/inet/ndpd.conf file.
How to Configure Your Router to Advertise Over Tunneling Interfaces
