IPv6 Administration Guide
traceroute(1M)
You can use the traceroute command to trace both the IPv4 and IPv6 routes to a specific host. From a protocol perspective, traceroute uses the same algorithm as ping. Use the -A command-line option to override this selection. You can trace each individual route to every address of a multi-homed host by using the -a command-line option. See the traceroute(1M) man page for details.
